So I've somewhat outgrown my current tool-storage situation so I'm looking to move my Repco toolboxes on in favour of something bigger. Not to say that these are small... All are in good condition. I use my tools, but I also clean them and lube the bearings on a periodic basis.
These are Repco series 2 tool boxes and feature
fully welded construction
double powder coating for a stronger,more durable and better looking finish.
gas struts
high quality KR Type drawer handles
full length ball bearing slides
Automatic Drawer Locking System and much more.
All drawers are key-lockable and foam lined. The bottom box sits on heavy-duty lockable trolley wheels and has a sturdy rubber coated handle for easy maneuvering in the shed.
This is the kit I want to offload -please note none of the tools pictured are included.
Specifics below
Top Box
6 drawers
660x307x374mm (WxDxH)
3 small drawers 170x275x50mm
2 large shallow drawers 569x275x50mm
1 large medium-depth drawer 569x275x75mm
The Sidchrome/ABW socket rails pictured will be removed before sale.
Middle Box
2 Drawers
660x307x251mm (WxDxH)
1 large deep drawer 569x275x103mm
Please note the marks are from shop stickers and I will make sure they're cleaned right off prior to sale.
Bottom Roller Cab
7 Drawers
127mm casters (2 fixed, 2 swivel with brake)
Dimensions 670x460x960mm (WxDxH)
5 large medium-depth drawers 576x380x75mm
2 large deep drawers 576x380x154mm
Will Freight: Yes at buyers expense, pickup is probably best for both parties
I'm chasing $1000 for the set which is a good deal less than new price. I may consider separating, PM me to discuss.
Thanks for looking
https://www.sau.com.au/forums/topic/452991-repco-toolboxes/
  • 4 weeks later...
Price drop to $800 or reasonable offer.
I really do need to clear these out in favour of something bigger so don't be afraid to inbox me if you're interested.
Cheers
https://www.sau.com.au/forums/topic/452991-repco-toolboxes/#findComment-7480163
  • 3 months later...
  • 2 months later...
  • 7 months later...
  • 2 years later...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
