  • Replies 345
  • 3 weeks later...
september/october.
they should have the driving events back again this year, the only reason was all that public liability insurance crap.
ive been in the driving events for the last couple of years, and it is really the only thing it has going for it.
i didn't bother to go down last year.
  • 3 months later...
Hi all,
Just picked up my R33 S2 gtst last week:
newly imported
12/95
manual
Silver
96kms
HKS sequential blowoff
apexi power intake
apexi turbo timer
?? boost guage
17'' jap wheels
exhaust (cat back i think)
not a scratch on it
Got it from a dealer with 12months rego and 1 yr "All States Warranty Network" warranty for $26k
Managed to get ins for $1800 which i was happy with, 23yo with 60% n/c
Probably, I work in Fyshwick and I've driven over to Woden a couple of times. in the last week (haven't turned off Hindmarsh toward the tip though).
Anyone know what a Pivot Air/Flow Conditioner (ACS-M) is. I found one hidden away in the gaping hole where the stereo should be...
It has a dial to adjust +- 6%...
Air flow controller/boost controller thingy?
Cool, I was next to a silver series 2 around a week or 2 ago and gave them a wave.
That air flow conditioner may be a little device to lean the mixures out a little. R33's run pretty rich usually.
Do a quick search through goggle and see what pops up.
You gotta love bonus bits.
J
Hey J & James,
Give us a call when Shell's pod is to go on. I have about 70 IOU's for you guys.
For Info James & J have so far installed the following for me:
1) boost controller
2) 3 inch turbo back exaust
3)Pod filter and bracket
4)pluged my BOV
Just let me know when and where?, we can have a Bar-B-Q and some cold ones
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
