Selling my r33 s2 1996 skyline
really clean and nice example of a skyline not hacked or butchered. no accident damage or history everything works great apart from the hicas light pops up every now and then but not that often. Liverpool area nsw
166,900km
Car has active lsd which is extremely rare
Car is fairly standard has a 3 inch exhaust
Blitz front mount
greddy turbo timer
greddy profec electric boost controller
Front and rear camber kit
rear toe arms
genuine gtr cluster (will come with standard cluster)
nismo gear shifter and gk tech handbrake
6000k hid
s15 stock wheels with decent tread
asking $8800 but open to offers only selling because I have found another car I would like to purchase.
Plates wont come with car
Edited by ln17up
https://www.sau.com.au/forums/topic/453531-red-r33-s2-for-sale-166760km/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
