[qld] Fs: Dba 4000 Rear Rotors, Bc Br Coilovers, Gktech V3 Arms, Diff Bushes, Subframe Bushes, Tie Rod Ends, 33 Gtr Cluster 15,517km
Contact: Jamie on 0420 856 four6four
Pictures: See attached (castor rods not in pics as I have to pull them off the car still)
Item: DBA 4000 series T3 slotted rotors to suit rear of R33 gts-t, will also throw in brand new QFM HPX pads to suit
Condition: Have been fitted to car only. Have not seen any use but I did wipe the rotors with brake cleaner as per instructions before fitting to remove the film
Price: $300 (I paid $352 for the pair of rotors and $79 for the pads from brakes direct)
Item: BC BR coilovers to suit R33 gtst. 8kg/mm and 6kg/mm spring rates (standard BC spring rate for the car).
Condition: These were fitted to the car and have been adjusted up and down a few times. They have not seen the road and have only been used to roll the car around on. There are some slight marks on the thread body from adjusting which are only cosmetic. C spanners, nuts, stickers, manual etc all in the box still.
Price: $800 (Paid $1299)
Item: GKTech V3 Adjustable Caster arms, rear camber arms, rear toe arms, rear traction arms, Solid subframe bushes, solid diff bushes, tie rod end kit and offset bush delete kit. all suit r33/34/s14/15
Condition: All unused aside from caster arms which were only fitted. Threads on some of the adjustable arms were quite snug but apparently this is common
Price: Castor, rear camber, toe and traction arms $400 and will throw in the offset bush delete kit ($700 new for arms)
Solid subframe and diff bushes $75 (New price was $110 for subframe and $50 for diff bushes)
High misalignment tie rod end kit $75 (New price $129)
If someone wants the lot I can negotiate as it will be easier for me.
Item: R33 GTR V spec cluster, has 15,517 genuine km on it.
Condition: Used but almost as new, few little bits of dust in behind the plastic if you look hard, no scratches, perfect replacement for those with misbehaving tacho needle issues.
Price: Not really sure what it's worth second hand but will say $250 as the others I've seen on ebay with 60,000km plus have been ranging from $300 to $400
Will the adjustable arms def fit an r34 mate??
Edit - sorry mate just reread and realised uve sold em
Edited by jase-r34
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
    • You're going to need all that and more to keep them from rubbing at the rear anyway, is my guess.
    • Looking at it now the battery clamp needs some love..  LOL One day, but not tomorrow, tomorrow I'm strictly a spectator, the only testing for me tomorrow will be on the coffee and food at the Cafe
    • I purchased some (used but new to me) Yokohama A050 Mediums to try out for the first time and fitted them up to one of my sets of Rays TE Fortesst's. Sizes are 235/45R17 front and 255/40R17 rear. They are very chonky compared to the same sized AD09 on the same sized rim. Some fiddling will be needed to make them fit. How much camber do these like as a general rule? I imagine more than the rear camber of -1.5' I typically run. So my plan is to target -3.8 front and -2 rear
    • If you want to test it under temperature, I think you should enter the One Raceway day tomorrow with Duncan!
