Heya guys & girls!
Just hoping if anyone is able to help me out here.
I have 2x fairly decent and not so old split systems at my current place which I would like removed and re-installed at my partner's property.
I've called a few air conditioning guys however they want either the same price as a new air conditioner or refuse to do the job.
So just wondering if anyone can help me out (cash & beer of course :))
I'm located in Canley Vale, NSW
Cheers!
How are your current ones installed?
As in is the outdoor unit on the same wall as the indoor unit?
Will they be installed in the new premises this same way?
Or is the outdoor unit a little bit away from the indoor unit?
Im an electrician working for an AC company. I do installs, repairs etc...
Also what you are wanting is basically a new install plus removal, so yes most will charge you a new install price, there are ways of saving some money by reusing what materials you already have it all depends on install type.
Pm me if you want to sort something out to save some money.
sounds good, I will PM :)
They're both 7 year old Panasonic Inverters and installed back to back at a fibro house atm.. it will then need to be installed back to back at a brick veneer house.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
