This is a controller to determine how much torque goes to the front and rear wheels. You can dial in more at the back for straight line speed and move the dial if you want better handling. I have only the one. It is brand new and custom made, I will be selling for $185, send a PM if you want it, I only have the one.
To clarify, this controller allows the driver to variably adjust the response of the factory torque control systems on the R32, R33 and also the R34's so that you can corner with more of an AWD feel and less oversteer. It works on the lateral G sensor. The amount is $185 AUD, PM if you would like to see pictures, BOOSTD - you have pictures now :P
    • Surely, just about any shop that has done a Skyline (or Supra, or RX-7, or EVO, or WRX) will have done E85. But perhaps you need to specify what type of car, what type of engine, what ECU, you propose to be using.
    • Try an oil additive. There's a couple of options for "easier shifting". These are essentially a similar idea to what Redline put into their Shockproof gear oils. I had a 2nd hand R33 (in fact, as of right now, it is still in the car) that simply would not engage any gear with the engine running, with normal gear oil in it. We dropped that and replaced it with Shockproof lightweight, and suddenly the gear lever did what it was supposed to. At a cost, of course, of the then ongoing damage to internals done by running Shockproof. But the synchros were already totally uninterested in life, so there was no loss.
    • I see what you posted, but how could a warning light be going on and off if there is no sender for it?  The only other explanation is that the wire that used to go to the sender from the warning light is earthing somehow in the loom or at the connector, or that you have connected the warning light wire to something (maybe the temp sender?).
    • The original pressure sender (switch) had the standard connector and the temp sender had the single terminal connector also. The pressure switch is gone and those wires eliminated from the harness.  I left the temp wire as I too used the temp sender to plug the extra hole. I was hoping for an easy answer but I guess I'm going to need to trace some wires to see where my ghost oil pressure light voltage is coming from or maybe I'll just pull the bulb out as there's no pressure switch any longer.
