No One Likes Street Racing And When It Blows Up This Bad. Usa.
Been a while since Ive read some car forum drama. If you're going to be doing something illegal, its not a smart idea to be filming it along with many other similar situations, in front of hundreds of witnesses.
Even if it does provide the rest of us with great entertainment.
