hi guys
im sure this has been covered countless times, but i got some funny reading and im just after a second opinion
Compression test values are as follows:
DRY TEST (no oil):
1 - 110 psi
2 - 105 psi
3 - 105 psi
4 - 100 psi
5 - 115 psi
6 - 100 psi
WET TEST (oil dropped in cylinder) :
1 - 120 psi
2 - 125 psi
3 - 105 psi
4 - 195 psi
5 - 150 psi
6 - 160 psi
the wet test threw me off about with how much variance there was, but as well as that it seemed quite low on the dry test
thanks in advance
cheers
ohh i forgot to mention its my mates r33 im looking to buy
just wanted to do a check before i commit....as far as i know it runs pretty sweet
Edited by stagea_1998
Why did you test it? Any problems?
If not just drive it. People get caught up and just confuse themselves with comp tests.
if it runs well and doesn't blow smoke, don't worry about it.
btw does it have standard cams? the number are low but cams can affect that (and also the exact testing procedure of course(
nah all standard internally theres just a few basic bolt ons
im pretty well inclined to say its fine but i always like to have a second opinion when im unsure
Re The testing procedure - figures do not seem consistent (bad or good) - Dry V Wet variances. Readings on some are all over the place.
I'd have some one else who does this often re-test first. It's just too inconsistent.
Eg. cyl 4 has jumped 95psi
Variances
10
20
0
95
35
60
thats what i thought ...its a massive jump!!
i did use a second tester to check as well after i saw that to confirm the reading and sure enough it was dead on
ive done plenty of comp tests over the years on cars me and my brothers have bought and with the same test procedure id get pretty consistent readings...so id say ive an idea what im doing lol
this ones thrown me though....
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
