17x 8 and 17 x 9 5x114.3 front offset +32 rear +37 came off R33 gtst
P1 buddy clubs IN BRONZE
80% front and rear dunlop formular FM901 in 235/45 and 255/40
very good condition with only a few small surface scratches that probly buffs out.
$1990 ONO
SOLD
  • Replies 40
sorry guys
pm isnt working for me so i'll just reply here
im willing to sell the rims on their own, i have had an offer of $1500 but cant get in contact with the guy atm so if anyone matches $1500 it is yours!
and im not sure if +32 will clear brembo, im guessing it might though.
thanks guys
sorry guys
thanks guys
cheers
Very nice. Now I know exactly how they would look on mine.
Nice, sleek, light.
Most importantly NO bling bling!
Mate is that the titanium silver or the hyper gold?
Inso could u send me some more pics like side on n stuff.
Like to see how much they stick out and how fat they look.
Are they 17 inch?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
