As pictured assorted Ross parts, 2 x rb25 gold balancers, trigger kit, 2 x dry sump pumps 4 stage and cnc oil pump mounts, toothed pullies, 2 x cnc dry sump oil pans, ati 1000 hp rb r32 balancer with dry sump mandrel, toothed power steering drives inc r33 power steering pumps x 2. Most parts brand new some used
Ati kit $750
Ross balancers $500 each
Hi Octain trigger kit $420
Ross trigger kit complete less balancer inc 2 x gt101 sensors, upper and lower brackets, trigger wheel for crank and cam $900
Cnc dry sump pans $ 1000 each, 1 brand new other used
Assorted dry sump pulley drives and sprockets
R33 power steer pumps with toothed drive $275 each
Can supply complete r32 dry sump kit inc lines, 4 gallon aviaid tank, pump, brackets, oil pan, oil filter housing adapter. Many more parts
0419362110
Please note the ati balancer kit (balancer and water pump pulley) is $750 the dry sump mandrell is $175 as per picture or $850 if purchased together, both are brand new, sorry for confusion
  • 1 year later...
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
