No dyno this week I've got a hold of an old fella that's going to work his magic on my carbs and I've got to get a fuel reg and get my dizzy re graphed again it needs abit more advance down low for the bigger camshaft
  • Like 1
Looks to be running pretty rich , and in answer to the earlier question, run a decent duct up from the side of the Rad and drill holes all reound the Filter body helped a lot as did inverting the lid, this however depends on whether it was one of the big sumbitch oil bath aircleaner's .
Yeah it's running pretty rich it's spitting fuel out the exhaust, I'm getting the reg tonight and playing with the fuel pressure, I've been told to run about 2-2.5 psi, apparently dellortos don't like a lot of fuel pressure.
3-5 PSI was normal for the average red motor mechanical pump, Fuel pressure shouldn't be an issue as the float in the Carb should be regulating properly, I'd look at the possibility that the float needed seats are not sealing 100 % as this can manifest it'self in a number of ways or there might be interference in the Choke bypass circuit that is loading her up with fuel at idle.
The audio above sounded pretty clean so it is likely a low speed circuit in the Carbs that needs tuning and balancing.
Just had another listen to the Idle video and I concur the suspicion you have the low speed circuit loading it up and the timing at idle seems off too (based on the sound)
Edited by MozzMann
  • 3 weeks later...
  • 3 months later...
post-134876-14423701237979_thumb.jpg new manifold for the old girl, I ended up blowing it up, so instead of rebuilding it I'm going to do up a 202 to group nc specs because I want to turn the Orange lc in a group nc car car hopefully try and get around the 280 to 300hp mark
  • Like 1
  • 1 month later...
Thought I'd put these pics up for the old boys on here to reminisce on the old day, few years ago I pick up a old roller sports sedan lc/LJ torana, just because it looked awesome, well last night I found some pics of it back in it hey day racing, this is reaching back in 1980post-134876-14466011098864_thumb.jpgpost-134876-14466011243268_thumb.jpgpost-134876-14466011598339_thumb.jpgpost-134876-14466011695511_thumb.jpgpost-134876-14466011806746_thumb.jpg.
This is the livery the car still has now, I don't have a full pic of how it sits now but this is the pics I have of it
post-134876-14466013236671_thumb.jpgpost-134876-14466013432032_thumb.jpgpost-134876-14466013929915_thumb.jpg
[emoji106]
  • Like 2
I haven't pulled it out of the car yet, but I'm pretty sure it's because the sump has no baffles in it , saving up for a ASR sump, , also doing a cash job on a vk and getting an accumulator setup off a xu1 for my motor. Should help it for next time
I'm not a real fan of rb30s in toranas but I'd put this motor in it for sure haha attachicon.gifImageUploadedBySAU Community1446774077.957018.jpgattachicon.gifImageUploadedBySAU Community1446774092.454850.jpg
gosh darn Yeah. :)
Edit.....how the hell does the F word turn into "Gosh Darn" LOL
Edited by GTRPSI
  • Like 1
  • 1 month later...
I picked up my sump today, I was told it was off a bianti series xu1 race car, I'm pretty happy with it.
post-134876-1450247873666_thumb.jpganyone know why it would have all the tiny Alan keys along the side of the sump?post-134876-14502479277795_thumb.jpgpost-134876-14502479627485_thumb.jpgi don't no why they have heated these little spots for???
  • Like 1
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
