That's what I was thinking they may of been for but the bloke I got it off didn't no either because when he brought it off the other fella it wasn't on there either, you can get crank scrapers of sonic fabrications for the 202 but I think they mount on the main caps instead of the sump, I might has to get one made up for a knife edge crank.
Would be hard to get one made that would follow the crank that far down.
Im guessing just a bit of right angle tin sticking out a inch OR better still, some mesh leading from the bolts to the bottom of the sumps other side to stop the oil foaming and break up the droplets......
I was thinking about running the right angle bit of tin along the side, and I found that you can fit a BA ford engine crank scraper to the main caps, looks like a good idea. What's your thoughts on this gtrpsi?would it be still worth while using this if I was using a knife edged crank?post-134876-14506524625009_thumb.jpg
Edited by Rbdirty30
  • Like 1
I recon it looks pretty good, id go with it, looks so nice there, almost like it was designed for it. :)
I ran a RB26 Windage tray on my RB30 bottom end build, i just had to drill and tap the holes into the girdle, you can see the holes in the pic below.
I also ran it with a crank scraper, but it took a bit of work to grind the right shape out while allowing 1-2mm clearance around the throws.
I got the scraper from the US but its not shaped, you need to shape it yourself.
IMG 1515
RB30 B
Edited by GTRPSI
  • Like 1
I better chase one up then won't be to hard finding one ,
My rb30 also has had the rb26 windage trays modified onto it aswell [emoji106]I don't reckon I'll bother with the crank scraper tho as mine won't see no track work or a real hard time, I'm getting abit over my gtr, it's taking way to long to get it finished , almost at the point of just selling it all as it is and doing the xu1.
Your crank scraper looks the goods!!
Edited by Rbdirty30
  • Like 1
Dont lose sight of the big picture with the GTR, im going through the same, ive told the family clearly, its not going to leave till after im in my coffin.
Mines been off the road for a few years now, busy with business and the son just had issues with his supercharged S2000 after a bit of brass from a sensor found its way into the intake manifold and then 2 of the 4 cylinders.
The other day i stopped at a set of lights and saw a S2000 and R32 stop next to each other, i almost lost all my shit and wanted to get home and finish all these jobs waiting......frustrations....simply not enough hours in the day.
Mines been sitting there for 2 years now [emoji20] so much $$ just sitting there and the dollars being tipped into it and the end doesn't look in sight.
That's sh*t luck mate! I no what you mean when you see a car and you instantly want to get motivated on your own car, but like you said time isn't on our side haha, one day. Bit of luck I'll have both going in the new year or atleast one [emoji106]
  • Like 1
  • 3 months later...
  • 3 months later...
578a27bdbc398_ImageUploadedBySAUCommunit578a27e45edd8_ImageUploadedBySAUCommunit
I don't weather this thread should be moved to the build section or not, but I started fixing the burnt wiring in my engine from where my carbs caught alight , it's slowly getting there, I've ordered some new wheels aswell, they should be here next week. And my new motor is coming along, I've ordered a alloy jzed head and a few other bits but that can wait for when I can put up a few more pics, plan is to have the torana ready buy October next year for the historics meeting here in Tasmania at Baskerville
So I was on gumtree and I came across an original locking fuel cap in pretty good nick and a fair price I had to have it, looks a lot nice than the original none lock twist cap 57909d5a98e9f_ImageUploadedBySAUCommunit
Then today my new wheels turned up, 13x9 group c sprintmasters .57909df6c2832_ImageUploadedBySAUCommunit57909e575684d_ImageUploadedBySAUCommunit
  • Like 1
On 3/21/2015 at 1:31 AM, GTRPSI said:
Get a 12-18" length of garden hose, (my parents use to crack it when they saw me hacking theirs), while engine is running start putting one end of the hose into the intake runner entry of each throttle bore and listen with your ear to the other end of the hose.
Move from port to port, making note of the diffrences in noise.
Adjust throttle stop for each one till they are all to as near as to identical as possible.
Point being any throttle thats open more or closed more will sound different, old school way of balancing the carbs throttle positions. :)
From there read plugs and adjust jets, also go back and re listen to the sounds if any need a tweak.
Back in my day vacuum gauges were hard to find and big $, i learnt that from a old time race engineer back in the late 70's who was adjusting and balancing side draughts in the pits, he was kind enough to show me when i was a teenager because i took interest in what he was doing and ive been doing them that way ever since he showed me.
My Old man did the same with his triple 1 3/4" SU's. 197RWHP on Bert Jone's (Sydney) Dyno back in the day.
On 4/11/2016 at 10:02 AM, Rbdirty30 said:
I brought a 4 speed Jerico straight cut dog box for the Orange torana on the weekend, probably doesn't need it but I wanted it haha
What ratio's are in it, my old man had one in his V8 Supercar back in the late 90's and it had like a 2.1 1st and it was a dog of the start line?
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
