The appeal by Stone Brothers Racing was against the penalites handed down following the Stewards' finding that their vehicle (Car #1) was in breach of technical rules C8.11.8 and C8.11.9 (AVESCO Operations Manual) in that the ECU wiring loom was found to include additional wires and a connector which were not permitted.
Running a NAWS solenoid maybe? lol.... Just another minor POS indiscretion and the revised punishment seems a lot more sensible.
Adrian
https://www.sau.com.au/forums/topic/45461-ambrose-appeal/#findComment-926707
Consistancy would be nice!
Saturday 20 March
PWR Racing was found to be in breach of the Rules, in that at the end of Race 1, post race scrutiny revealed that the Control ECU Loom was not in compliance with the Rules. A penalty of $1,000 was imposed.
Saturday 20 March
Car #28, Matthew White, was found to be in breach of the Rules, in that at the end of Race 1, post race scrutiny revealed that the Control ECU Loom was not in compliance with the Rules. Stewards imposed a reprimand.
Going by previous breach of the same regs the 5k fine is still too high and the intial penilty was just a joke..... Looks like the Trevs are just going to have to win some races in order to win the Championship hey................Go Marcus
https://www.sau.com.au/forums/topic/45461-ambrose-appeal/#findComment-926879
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
