Hybrid intercooler kit Chrome plating coming off pipes
im so mad with my cooler kit rite now..
got a hybrid one for an r34 gt-t thru that damn group buy ages ago
just started installing it thise weekend
so far i have been working on r33 instructions that they gave me which is quite different
had to make my own brakets as theirs do not fit!
been working on it for 2 full days straight and now i cant get the bonnet to closed as they still hit fan blades even tho ive cut them enuf already
oh and not to mention asked for red silcone back then and got red and they was told they had no blue left so.....
not happy
what should i do!?
this thing is f**king my car up
Power digger actually have an R34 there that they are sponsoring and the cooler they put on it fit nicely.
Plates are ONFILE its a yellow R34 GTT.
It seems that there is alot of mixed reaction and fortune with these kits.
All the kits ive had personal experience with went it with only the slightest modification and they havn't had any problems at all.
Maybe its just luck of the draw.
Yeah i had a fun experience with mine as well Driver, 5 hours my ass... I've had mine on for about 2 months now and the piping is already starting to bubble, its not fazing me that much not to concerned with the look as long as its doing its job!! The thing i was most peeved about was there was no return for the standard boost solenoid in the in let manifold and when i rang powerdigger they just said yeah you'll have to that yourself. I did take the opportunity to remind him that this was a "kit" custom built for R33's so.... That got me no where so out came the drill.
Works good now thou so can't complain really. And had a Link ECU installed the other day and the dyno tuner and i where both impressed with the combined packages result so all well that ends well... for the time being.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
