Hello,
I'm finally looking at doing some mods to my car - but since the smallest things are difficult for me (im not a mechie) I thought I'd try some heatshielding.
Does anyone know which bits are the best to heatshield? I know some are not good to heatshield as you don't want the heat to stay IN as much as you want it to dissipate.
Any ideas/setups/photos and general info would be greatly appreciated :D
https://www.sau.com.au/forums/topic/45537-heatshielding/
Generaly one would heat shealid somthing that needs to be protected from heat and not go willie nillie with a sheet of metal.
suggestions:
1.Brake fluid reservouir or anything that holds fluid and dosent tolerate heat.
You should also try cold air ducting its a noobs job and its effective.
https://www.sau.com.au/forums/topic/45537-heatshielding/#findComment-927869
Hello,
hey, i would say heatshield your airfilter or pod, if u dont have a stock airbox. Very easy to do and is a good idea :D
1st and 2nd photos r of the shield, last is the air filter without the sheild on
hope that helps :D
Mike
https://www.sau.com.au/forums/topic/45537-heatshielding/#findComment-927870
if u do get extractors heat sheild them by using an exhaust wrap, it is best to keep the heat in the exhaust bits. Good for exhaust flow and good to keep underbonnet temperature down. Do not heat sheild the stock manifold or stock dump, cast iron does not like to be wrapped and may crack. If u do get an aftermarket dump and front pipe also wrap these up. Wraping up some of the intercooler pipe may also be a good idea. U don't want the warm/hot ambient under bonnet temp to heat up the air inside the pipe for obvious reasons.
https://www.sau.com.au/forums/topic/45537-heatshielding/#findComment-928456
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
