Hi guys,
I've got some gear to sell that is surplus.
Apexi S15 PowerFC DJetro. This is the MAP version of the venerable PowerFC. Comes with EL Controller, looms and ALL sensors in as new condition. $1100 ono.
http://www.nengun.com/apexi/power-fc-d-jetro-free-t-shirt-offer
Autronic SM4 Ecu. Motorsport grade ECU used on everything and anything. Comes with all looms and sensors. $1100 ono. SOLD
http://www.mrm-racing.se/index.php?pageid=SM4e
Apexi ACV-R Boost Controller. Doesn't need an introduction. Comes with all looms and sensors. $350 ono.
http://www.nengun.com/apexi/avc-r
Blitz ID3 Boost Controller. Probably the best EBC you can buy. Comes with all looms and sensors. $350 ono.
http://www.blitzpowerusa.com/techsupport/pdf/sbc_i-d_iii.pdf
Tien Flex Coilovers. Excellent condition with Apexi springs up front. Comes with EDFC synchros and controller but one connection is broken so it's all thrown in for free. $1200 ono.
Nissan S15 GT Leather Seats. Excellent condition. $500 ono.
Velo GP-90XL in Red. Excellent Condition $500 ono.
I'm flexible on price - make me an offer! Located Melbourne, CBD.
Alex
0447738908
Hi mate I've had it in the car since I bought it in 2011 and it's worked without any issues since then. I'm only selling it because I'm upgrading to a Wolf V550 which has bc built in.
There's a few pics on this page http://forum.jdmstyletuning.com/showthread.php?49703-Alex-s-S15-S15-and-180SX-lt-3-S-Chassis/page31
If I don't reply on here shoot me a msg on 0447738908 cheers
  • 4 weeks later...
Update!
Apexi S15 PowerFC DJetro. This is the MAP version of the venerable PowerFC. Comes with EL Controller, looms and ALL sensors in as new condition. $1000 ono.
Apexi ACV-R Boost Controller. Doesn't need an introduction. Comes with all looms and sensors. $250 ono.
Blitz ID3 Boost Controller. Probably the best EBC you can buy. Comes with all looms and sensors. $300 ono.
Tien Flex Coilovers. Excellent condition with Apexi springs up front. Comes with EDFC synchros and controller but one connection is broken and the wires are too thing for my soldering skills (which aren't great) so it's all thrown in for free. $1000 ono.
Old model Velo GP-90XL in Red. Excellent Condition $400 ono.
S15 Nismo Cluster with ~17,000 km Excellent condition $500 ono. SOLD
Txt for quickest response.
Alex
0447738908
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
