If both pumps are only on at full tilt, and even better if he reduces the output of one pump with he other off for idle etc, then when both pumps are on for full tilt power, the injectors are diverting the fuel away from the fuel return line to a much nicer location, which will help keep fuel pressure lower as there's not a blockage/build up of liquid.
It's 2024, just PWM them instead of staging. If OEMs are PWM, then you should too, especially with all the fancy ECUs on the market. FWIW even my shit box with a mediocre ECU has PWM fuel pumps set up to ramp up and down with RPM x MAP. -
Found another MX5 NB that looks Ok in the pics to look at on Saturday, this one is a series 3 Luckily they are both in the same direction Finding unmolested or non-track car examples is proving tricky I've got a hard budget, I'll access the situation and attempt some "polite" good old fashioned negotiating (low balling)
Anyone visiting Tokyo? If so, hit me up. Be keen to have a beer or 10
How are you staging yours? I am running these 2.. and my fuel was heating up.. I had to stick a fan assisted cooler on the return.
