Hey guys for sale is my Recaro sr-11 driver seat out of an late model evo.
Its almost brand new, no signs of use or wear. Was taken out of the evo to make it a race only car.
Was going to fit it to my r34 but I've now decided to working on the car.
Its black and would suit any skyline interior.
Comes with stock rails
Located in Melbourne but can post
$750
0450232121
https://www.sau.com.au/forums/topic/455942-recaro-sr-11-as-new/
They are fixed back and reclinable, this one is obviously reclinable.
Reclinable in coupes have that quick fold handle (like in the EP3R), and the ones in ego's like my one dont have the quick fold handle so you have to fold it forward manually with the handle on the side.
That being said i usually don't get out for people to get in, they can go in from the passenger side :yes:
  • Like 1
Bump - $699 price drop for sau users only
Note: its just the driver seat, as photos state its a reclinable seat
Interstate buyers welcome, postage would be about $30 to $40 anywhere in australia
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
