Dell Inspiron 5100, 12 months old.
  • P4 2.8 GHz
  • 1GB DDR RAM (512MB x2 PC2700)
  • 40GB Ultra ATA HDD
  • 15" SXGA+ LCD (1400 x 1050)
  • 32MB Radeon Mobility 7500C Video Card
  • Windows XP Home Edition License
  • 24X CD Burner/DVD Combo Drive
  • 10/100 Ethernet, 56K V92 Modem
  • 2x USB 2.0 Ports, 1x S-Video, 1x FireWire IEEE 1394
  • AC Adapter Charger
Laptop is in 100% working condition. No restore CD but have drivers on CD. Battery is in excellent condition and will have 20 minutes to spare after watching 120 minute DVD.
Warranty has expired. Instant refund only given if fault is found within 7 days, not because you change your mind. I am selling because I have upgraded to a newer laptop.
Price: $1650
Sydney buyers have preference. Price is firm, please no offers.
Any questions or to organise inspection, please contact me on 0415 807 888 for instant response or PM and I will try to reply same day as I check my email once daily.
Pic 1
Pic 2
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
