For Sale
R34 GTT Plazmaman plenum with throttle body. Both items brand new was only fitted to calculate vaccum line path. The kit was going to be fitted to the car but it has been written off. So im raising cash for next project.
Throttle Body is a plazmaman 72mm throttle body anozided black.
Plenum has been powder coated "Kingsport Grey" gives it the stealth look but when you shine a light to it you can see the glither. This along with candy red rocker covers, which was my idea will make the engine bay look at lot better and more accessible for spark plug changes.
Included in the kit are the pipes required to link the plenum to the cold side of the intercooler. Ive included all the studs and fittings and vacuum hoses required to install right away.
Asking $1500
Willing to split them if there's interest.
Text or call 0417764194
MATE if i had not have just got my whole front mount custom done like 3 days ago, this would be on its way to my door! :) good luck with sale bro
ps sorry to hear about the car, was watching your build too :( :( sad news man
  • Like 1
  • 4 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
