hey there boys and girls
i am looking around for the best deal i can get with a big shed
size i am after is 9x11 and height of 4m and to have concrete poured into the shed instead of a slab and to be 200mm thick to be able to fit a hoist
at the moment i have been contacting a couple place and soo far i have been qouted 28k to 32k and the concret cost was about 7-9k that was already included in the qoute
anyone out there know of any good place i should check out??
thanks
https://www.sau.com.au/forums/topic/456408-shed-builders/
The whole slab does not have to be 200mm.
(in fact my slab is ~100mm and I have a hoist). Most hoist manufacturers offer extended footprints (spread the load) on their posts to allow for skinnier slabs :)
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7529401
The big metal plate in the pic is an option, however other options are the big metal plate (not as big) actually manufactured as the base plate for the hoist. ie no need for attachment, it is the base.
Contact Gav or Maree at HAPP and ask anything you need to know about installing/specs/slab requirements. Tell em Mike sent you and they will sort you out.
Edited by MagicMikeZ32
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7529420
That's about right for a shed of that size. My 9x6.5x3.6 was 15k for just the kit, then 6k for concrete (I only did half pad at 200mm for my hoist), then I installed it which was a pain in itself
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7531820
Bit of advice, pay someone to do it. A shit tonnes easier, it gets done right the first time and properly, and all those people that offer to help but not show up on the day and it takes you 5 weeks to put it up (may have happened to me)
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7533250
yeahh i was dreading the idea it would take a lot longer if i was going to do it and stuff up.
thanks for the for giving me the idea in only having half the slab 200mm i may do the same just have the area i will have the hoist 200mm
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7533912
  • 2 months later...
alright, shed has gone through council and i will be putting the slab down in a couple of weeks, as this is on a vacant block (not building a house yet) anyone have an idea on how much it would cost to get power hooked up? and any tips on wiring for the shed?
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7567739
Get a couple of quotes for wiring, offer the sparky to dig the trench and lay cable down. Also offer to TA for them, pre-run the cable in the shed, anything to make their time at yours less.
Get at least 2x 15amp power points put in just in case you want to get a welder and some hoists run 15amp. Get double fluros for light, I have 2x in each bay lights up like a mofo. I also have 6x double 10amp points, 2x 15amp 1 of which is hanging from the ceiling
I did all the pre-wiring and trench digging for my sparky made it a lot less painful on the bill
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7570957
pretty much similar to what i was thinking,
and what you mean by pre-wiring is that you have all wiring laid out to where you would have it and the sparky just connects everything, am i right???
how did you run the cables into the shed, i was thinking of something like having some conduit through my slab then underground
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7571417
Yeah run all the wiring to where you want everything, then the sparky comes and finishes it off.
I ran them from my house fuse box all the way down to the shed, ran the cable through the orange conduit 600mm underground. It now runs under concrete. Was quite a bit of digging but it saved me a lot
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7575756
Just a word of warning. That steel base plate does very little to spread the load. It will be effective for the first 20mm past the standard foot plate (if you're lucky) then the rest is there purely for show. If you want a proper base plate, it needs to be gusseted to properly transfer the loads to the edges, or be much thicker than what's shown in the photo
As for tips on wiring the shed - LOTS of power points (including at least one 15A point). Also LOTS of overhead lighting. You don't need to use it all, but it's infinitely better than having power boards and extension leads all through the shed.
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7578543
  • 1 month later...
Bunnings stuff last me a year before having to recoat. That was a year of heavy traffic though as I was working in there everyday.
The more industrial stuff lasts a bit longer but it also costs more
https://www.sau.com.au/forums/topic/456408-shed-builders/#findComment-7611303
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
