Hi I've got a 95 GTR33 which I haven't start for years currently when i try to start the car I found the fuel pump was gone so I replace the pump also replaced the plugs but the engine still not fire up anyone know why or anyone know how to make it start please give me a hand. I've try another battery even jumper cable from another car still no good.
If someone can come to my place and help me out I will pay for it thanks
https://www.sau.com.au/forums/topic/456425-my-gtr-33-wont-start-up/
More details always help. What have you checked so far? All electrical connections and fuses working? Can you hear the new pump priming and the car cranking but no spark or what? It's a no brainer but make sure oil and filter is changed too. You've probably glossed over something that you unplugged or forgot about years ago, or if it was running when you last stopped it then something has seized/failed over the years.
Remove the cas plug back in connector to cas, with the ig on and dash lights illuminated go back to the front of car and spin the cas in the cranking direction as if the engine was cranking. You should be able to hear the fuel pump run and injectors pulsing along with coils sparking.if nothing happens then it's an electrical issue either supply problem or a trigger fault. Hope this helps
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
