There are convenience shops everywhere and they all have ATMs that don't charge fees for using
You mean I can use this debit card to get the cash out of it ? Wow ! Thank you Trev [emoji7]
Debit card ok , so I have to remember the PIN numbers and key in the pin every time I spend some
Monies ? [emoji28] she said it's all activated but I will go online and to ensure it's all
Good.
Yup international roaming - why is that ?
You'll need signal to top up.
When I first used it I had the problem that I couldn't top up my card because my bank sends me a code to use when spending lots of monies. I didn't have international roaming so I couldn't get the code. Had to apply to telstra to hook me up
  • Like 1
I'm good right now , I'll top up more money from here before I leave to Japan , I was waiting for the cash passport card to arrive and apparently it's easy to reload online.but thank you for the tips , I hope I don't get into any trouble especially when I'm in snow [emoji300]️ area
Why the fonts is different ?
They have 3 alphabets. Used at different times. The style you used is for words stolen from other countries.
The style I used is for words/phrases Japan made up before meeting the western world
Oh ok so yours is more authentic [emoji28] I hope I don't need to use these in writing when I'm in there [emoji28] all I want is shop and eat [emoji28]
