There are convenience shops everywhere and they all have ATMs that don't charge fees for using
You mean I can use this debit card to get the cash out of it ? Wow ! Thank you Trev [emoji7]
Debit card ok , so I have to remember the PIN numbers and key in the pin every time I spend some
Monies ? [emoji28] she said it's all activated but I will go online and to ensure it's all
Good.
Yup international roaming - why is that ?
You'll need signal to top up.
When I first used it I had the problem that I couldn't top up my card because my bank sends me a code to use when spending lots of monies. I didn't have international roaming so I couldn't get the code. Had to apply to telstra to hook me up
  • Like 1
I'm good right now , I'll top up more money from here before I leave to Japan , I was waiting for the cash passport card to arrive and apparently it's easy to reload online.but thank you for the tips , I hope I don't get into any trouble especially when I'm in snow [emoji300]️ area
Why the fonts is different ?
They have 3 alphabets. Used at different times. The style you used is for words stolen from other countries.
The style I used is for words/phrases Japan made up before meeting the western world
Oh ok so yours is more authentic [emoji28] I hope I don't need to use these in writing when I'm in there [emoji28] all I want is shop and eat [emoji28]
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
