11 minutes ago, t_revz said:
might go check if any mice were silly enough to get caught today
they sound like possums wrestling when they are above our room
no mice today.
they must be able to smell death in the air
so i flushed the tank out today and started running the ute on water with no methanol,
its an 'ol slug again :( definetely going back to methanol. max exhaust temp 515C on diesel and water. 565C on diesel, water and methanol. safe as houses
  • Like 1
its an 'ol slug again [emoji20] definetely going back to methanol. max exhaust temp 515C on diesel and water. 565C on diesel, water and methanol. safe as houses
Nos next?
  • Like 1
Just now, t_revz said:
such as?
thought you only needed wheel arch guards?
yes proving a little more difficult to get than i had hoped, had 2 people on fb but neither has got back to me with freight detail so i'm just looking into other options
another reason to delete FB
Typical huh
