Show us your realistic game wheel!
The skyline has a full face npc clutch that is nearly on the floor (awesomeness for me) took him out to Belmont Park to practice for about a hour and a half the other week. When I got back in it was like a Honda!!!
I've got an exedy hypertwin. Would never get again unless dedicated race car. Its a strong yet stubborn POS
Coolness, the npc has a bit of slip if you launch it hard in first but has great bite to chirp or spin second. When it's cold it's real close to the floor but warmed up you can pretty much nanna it round. I've got the idle set @900 which helps and stops juddering? Probably a bit high but seems to work the best on the nistune. I've always wondered about the twin plate?
Our xr8 has the standard high capacity single clutch with a six speed and a small child could drive it easily. ie: my wife. The Nissan has a short shifter so when I get in the Ford it's like driving a soggy lounge chair!
There is a 2-3mm slip window. Either side of that it's fully in or out. Can make taking off at the lights embarrassing if I'm up front
Rump rump bump bump blut blut whahhh, bruuuurt, Seeya later comonwhore and falcoon. I'd get the clutch right at the next lights but you've already lost once!
  • Like 1
Nothing worse than having to fly past a sv6 automatic at 70kph because you f**ked it and didn't think that anyone could be such a tool as to tell his missus we beat a skyline while he's looking at the tail lights:-( also hard to explain to the policeman why the tyres were spinning through the gears when you had to launch it hardO:)
That's what I tell the wife driving the Nissan. All on and all off. Treat it rough it drives smooth. Treat it smooth it drives rough. True story!!!
My npc clutch is pretty aggressive, kinda on or off. Makes for great laughs watching me kangaroo on the freeway in the mornings lol
Check out. Vietnamese uncle highway patrol. on you tube! Wished to post the link but couldn't work it out. Yourchonny YouTube channel. Funny as!
  • Like 1
Nothing is funny when you have run a 8. Would love to check out the run. If you can send a link?
