Hay guys!!!
Found a great gift idea for next mothers day. Order yours now, before they sell out!!
https://www.dezeen.com/2015/04/26/21-grams-sex-toy-contains-ashes-of-dead-partner-mark-sturkenboom/
Gee dale that's a oddballer gift. How did you get on with the back?
Ok first mod’s done ! Black
Glossy looks awesome!
2nd mods paid -HKS stainless with titanium tip ( exhausts )
Now the 3rd pictures , ok apparently the clanking noise is I need a new front upper control Arm as picture attached - why the feck it’s so expensive !
I’ve rang Nissan’s they said it’s only few hundred dollars GS josh wants it $1700 who should I trust or know better ?
Apparently I’m not an aggressive driver ( drive like an old women) [emoji28] hence the J hook make some noises too ! I need to put my foots down once a while - where will
Be safe for
Me to do this ?
Apparently I’m not an aggressive driver ( drive like an old women) emoji28.png hence the J hook make some noises too ! I need to put my foots down once a while - where will
Be safe for
Me to do this ?
Are they uprated ones for 1700? Otherwise ud be better off going nissan lol
  • Like 1
I’ll find out more tomorrow, not sure if Nissan’s knows what I’m talking about , I have the picture so I’ll bring it tomorrow with me
  • Like 1
Cars looking gd tho!!! Thats all that matters!
  • Like 1
Talk to Hanky
I did and tried to call him , must be dating.
All I need is the bush brush but sadly it’s not separate item
, come with the arm. Not in rush , I prob can pick up straight from Japan. And I have a friend who works in nissan Wangara who can install it for me
  • Like 1
Sounds like the go to me.
What did u use for the footing?
The sand on our block is class A and the house and shed pads are built with it so I just ran a compactor over it then laid them. They are only 2 high so I’m not concerned
