I got our CNC guy at work to make me a set of Roll Centre Adjusters/Spacers for my R32 GT-R. (Will fit R33's and R34 GT-R's as well)
These are a direct copy of the Ikeya Formula, Moonface and Cusco spacers (without their high price!) and I have had them made in high grade 6061 billet alloy and will supply them with grade 12 high tensile bolts.
When you lower the car, the suspension arm angle is compromised as is the "roll point" these correct the angle by spacing the lower arm down to a normal like point to help this problem, they only take about an hour to fit (you will need to get a wheel alignment after fitting, and requires you to have some form of adjustment for camber and caster)
I am getting more sets of these made up now, and at $180nzd including the fasteners they are soo much cheaper than the others available......and are an exact copy.
PM me if you would like a set.
Chris.
Edited by Sub Boy32
https://www.sau.com.au/forums/topic/457233-roll-centre-adjusters-r323334-gt-r/
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
