For Sale
Hi guys, Looking to sell my 1998 Nissan Skyline R34 GTT.
I'm no longer driving it and walking to work now + riding a bike. I would like to sell to an enthusiast through the forums that understands Skylines. Very clean and well kept vehicle. Always garaged.
Colour: White
Klms: 145XXX
Engine: RB25DET Standard Turbo
Mods: Blitz LM Pod Filter, Gizzmo EBC 8psi, Custom cat back exhaust, Splitfire Coilpacks.
Transmission: 5spd Manual. Brand new HD Exedy clutch - installed Jan 2015
Suspension: BC Coilovers, 24mm Whiteline Swaybars F/R
Brakes: QFM HPX Pads, Machined Standard Discs
Wheels: 18x8F +18, 18x9R +18 RAYS Gram Lights 57f-pro
Tyres: Dunlop Sport Maxx RT F95% R25% tread
Body: Standard + Nismo Side Indicators
Interior: Standard + Dash LED kit
Stereo: JVC Bluetooth H/U + Carrozzeria speakers F/R
Other: Paint is not 100% Has stone chips from highway driving on front bumper. Does have a couple of carpark dents from people parking next to it at shopping centre's. Will need new rear tyres, Nil mechanical issues. Will not be sold with custom plates.
Vehicle serviced by family mechanic with quality Penrite oil 10-40w.
Located: Brisbane, QLD
Price $13000 Negotiable.
post-36801-0-33545600-1434354968_thumb.jpgpost-36801-0-15559800-1434355079_thumb.jpgpost-36801-0-60694800-1434355134_thumb.jpgpost-36801-0-16835600-1434355237_thumb.jpgpost-36801-0-30901100-1434355184_thumb.jpg
https://www.sau.com.au/forums/topic/457496-qld-1998-skyline-r34-gtt/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
