Hi,
So the r33 has developed a misfire again. Strange thing about it is it's only in first gear and very very seldom it happens in second gear too but happens every single time in first when I boot it,but if I build the boost up slowly it's fine.
It isn't like the coilpack related misfire I had before where it just stutters,this time between 4-5k it splutters and pops and bangs
Doesn't happen in 3rd 4th or 5th at all.
I'm running stage 1 mods plus walbro pump,benchmark coilpacks and rsp stage 1 ecu.
Coilpacks were newly fitted in February of this year so I'd imagine it isn't them although I wouldn't rule them out.
Spark plugs wer put in around 5 months ago and are gapped correctly.
Today I took all plugs and coilpacks out and all look normal.
Changed air flow meter with no difference.
New lambda sensor yesterday which again made no difference.
Car is running perfectly bar the misfire and is going as well as I could expect power wise through the gears.
Any ideas on what to try next?
Think I'll borrow a set of coilpacks from someone local to try rule them out or so I can sent them back under warranty if needs be but I'd imagine if they were at fault I'd get the misfire in all gears and especially in higher gears at full boost due to being under more stress/load?
Should I be changing the plugs again even though they are only a few months old and have done less than 1000miles? Again I'd imagine plugs would make it occur in more than just first gear though?
Any suggestions would be great.
Thanks
https://www.sau.com.au/forums/topic/457944-misfire-in-first-gear/
What do you mean advanced timing is correct? First I've heard someone say that in relation to an efi car.
What's a stage 1 ecu?
Only in first is odd, but the rev range you mentioned is what a coil pack misfire would first become noticeable.
What gap plugs you running?
Ignition timing at idle.
Stage 1 ecus are made by a lot of different companies,it's basically a chipped ecu I suppose,company maps a skyline for x mods and then puts that map on multiple ecus. Obviously I know this isn't exact to my car but they are generally used to get rid of the flat spot from running higher boost etc on the stock ecu and the car has been fine for months whilst running this ecu. I have an apexi pfc lying to go on the car but no point fitting it while the car is misfiring.
Plugs are gapped to 0.8,heat range 7s.
Yea I just find it strange that a coilpack would only cause a misfire in first gear though,last time they went I had the 4-5k misfire in every gear. I'm going to fire a set of plugs in it tomorrow to check,again I'd expect them to show in more than just first gear and I'd especially think they would last more than 1000 miles.
Forgot to mention I also replaced the fuel filter incase it was causing a problem and still no luck.
Edited by Ep82jm
This is not gran turismo. We use big boy mods. We don't have stages of hektik modification.
And it sounds like spark blowing out.
LOL! it was bought just to see if it got rid of the flat spot I was experiencing when I first got the car. Have collected bits to run "big boy mods" and will be getting them all fitted during the winter while the car is off the road.
Thanks for the suggestion! So new plugs and gapped to 0.8 again or should I drop to 0.7/6?
Yep drop them to 0.7/0.6 and see if the miss is gone. It would be a quick way to see if you have weak spark.
Then report back
Ok so i dropped my original plugs down to 0.6 there and the misfire is gone!
So should i just leave them at that or is that only masking a problem? E.g coilpacks breaking down and not producing a strong enough spark? im only running .85 bar so i would have thought 0.8gap would have been ok for that boost?
You need to get yourself a new set of coil packs then you should be able to run spark plugs at 0.8 gap again.
If it were my car running that little boost I'd leave it at 0.6 gap til you can get some new coils.
Coils are only new 5/6 months ago too so ill fire them back under warranty.
Thanks for your help in getting it sorted,appreciate it!
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
