  • Replies 75
SLOW_VL... back again danny?
i could chance it in a matter of second if you want.
And just on that, Leewah's GTR, and Nige's Supra are
about 85%, to be confirmed at the end of the week
with maybe 1-2 more high HP GTRs :)
Ok, the 100% interest (guys that actually have thier cars now) is like this
DJ_L3thal
KamikazieR33
abcent
krzysiu
Much
m_rickards
And my car.  Making 7 people that actually have cars to enter.
Im not counting guys that aint got cars as many things could delay them getting 'em.
And there is a question on two more... Leewah's GTR, and Nige's Supra.
But they are not yet confirmed so we wont count them either.
What do you guys wanna do? its upto all of you.
Cost will probably be around $140 per entry.
- ash
Il definatley be over with my car.
  • 1 month later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
