FS: R34 GTR Fibreglass Rear Bumper Diffuser Add On
Brand new unpainted, opened just to take a look.
Sold my car so no longer needed.
Price: $360
PM or get me on 0402 292 385
Cheers,
Will
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
