Greenline.jp (insert any outside OZ part supplier) + import tax?
Hi all,
I'm looking at getting a Power FC (A.P Engineering special version) from Greenline.jp , it works out to about $1400 not including freight.
What is the go with import tax?, will i get stung for it?
Anyone who has ordered parts from outside Australia can you let me know,
Cheers,
Rob.
You may well be, so plan for any "unexpected" costs just incase....
I got my AP Power fc from someone who already had imported it. Got the comp + hand controller still in the origional boxes for $1600 :P Have a good look around first :)
Ordered a turbo from Greenline. Customs in Adelaide held it requiring a proof of cost receipt. Greenline was more than obliging to re-write the one I lost at a price we thought I had paid for it. The basic rule at customs at the time was that anything over $1000 needs a customs broker. I found one that charged $80 to do the job. He works out what it costs. He looked up his book and put turbos under centrifugal pumps etc basically 4% (lucky). Add this to the price on the receipt and then 10% GST. I got away with it for a bit over $200.
Thats the process. To be able to just go into customs and pay a fee after showing a receipt it needs to be under $1000. They didnt even open the box for my turbo. The best idea would be to have a reasonable price marked on the box that wont raise suspician. I didnt. As a rule of thumb if anything attracting customs duty of less than $50 is not worth the paperwork for them.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
