Got a Used R33 GTR Gearbox with OS Giken 5 speed gear set.
In great condition, there is no abnormal noise or clunking from the gear set.
No Oil leaks or damage to the bell housing
It has been converted from Pull to push.
Comes with Transfer case, gearbox mount, sensors and release fork.
Gear Ratio: 2.695 1.703 1.236 1.000 0.826
$4000 ONO
All inspection Welcome
Located at Mortdale 2223.
Please contact me on 0416 766 449 or PM if you have further questions
Can post anywhere at buyers expanse.
600x400-2015062500106_zpsplczxdf8.jpg600x400-2015062500110_zpspebwujoh.jpg600x400-2015062500108_zpsydsm5ax7.jpg600x400-2015062500109_zpsfyucbdxe.jpg600x400-2015062500104_zpsf9x1hdtv.jpg600x400-2015062500107_zps4gxlo2m3.jpg600x400-2015062500102_zps6012jbd7.jpg000001_m_zpsouoa7xg8.jpg600x400-2015062500105_zps0nveaikv.jpg600x400-2015062500103_zpswhkvg6kr.jpg000002_m_zpsxv2tznin.jpg
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
