Hey, been looking for similar problems on the forum but wasn't too sure still.
Basically, my m35 stutters when driving slowly and turning tight, happened the first time when doing a U turn and since, when I am parking/reversing/...
I can take a video of the car doing it if you want to help explaining the problem.
I have an extra unrelated question. There is a small switch just behind the panel where the obd2 connector is, anyone would know what it is?
Thanks!
Thanks!
shudder could be because of the "tight corner phenomenon" and the 4wd system but thats just a guess. The switch sounds like it could be to turn on the attesa pump when u need to bleed the system
Ha! I've pressed that switch multiple times and not too sure in which position I left it :/
The shudder is quite intense once it starts, is there a way to easily turn off the 4WD to validate that ?
All this is just speculation tho, my car has the shudder at full lock too ;). I guess for the switch you could flick it on and off and listen for your pump under the back right hand side of your car while your car is off. if the pump don't turn on then its not the switch lol
No there isn't an easy or safe way. These have a different Awd system to the c34. It is not good for the transfer case. The only way to properly make it rear wheel drive is to pull the front drive shaft
Took the car for a ride and couldn't get it to shudder again so no video yet of it..
For the switch, I tried to follow the cables ( red and black+red) and they go up in the ride side of the steering wheel in the dash.
Maybe it's related to the alarm or something. The car also has this little remote to start it from outside (which doesn't work).
The switch is definitely not stock as it was fitted with screws in two holes in the lower dash just above the pedals. Can't see any light turning on/off when playing with it.
I never got the remote with my car. I just done some research to find out what the switch was for. Mine has a silver sticker above it with Japanese writing. Had it translated and yeah it is remote start
Ha! That's it then, got the same sticker so that's sorted out ! I'll get a video when the car shudders again and put it here, should help with the troubleshooting. Weird that it doesn't happen every time (maybe only when really hot, will have to test)
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
