Hey all,
I have two pieces of music equipment for sale. They would suit a budding producer and both items are in mint condition...
Item 1: Roland MC-505 "GrooveBox" music sequencer
These still sell for over $2,500, and I bought mine about 4 years ago for roughly $2,200. It has ALWAYS been kept under a dust cover, and has probably only received about 80-100 hours use over the whole time I've owned it.
Item 2: Yamaha DJX keyboard
I've had this for about 2 years, and paid about $800 for it. This too has ALWAYS been stored under a dustcover, and again has had hardly any use over the time I've owned it (maybe 50 hours at a guess, if that).
So, how much am I asking for them?
The MC-505 is going for $1,200, and the DJX for $500, and for those who wish to buy both together I'm asking for $1,500 even.
Will try and post pictures/photos tomorrow, please PM for more details.
Nick T.
Phone: 0414-38-55-95
email: [email protected]
Images attached!
The first one is the Roland GrooveBox, and the second one is the Yamaha keyboard (obviously).
Dammit I am really interested, but I was looking at buying something like this later in the year. At the moment its just not feasible until I find another part time job.
If you still have it approaching the end of the year I would be very very very interested,.
Viscount,
it looks like you might be the lucky buyer, the way things are going at the moment... :P
Nick
I am still very interested. I don't have much of a clue about production and have a beast of a computer with software, but no hardware. I'm currently asking some friends in the know about the deal and getting some advice.
I think I would definitely be interested in the keyboard, but I'm not so sure about needing the groove box.
  • 3 weeks later...
C'mon people,
just think - the money you give me in exchange for the keyboard, or sequencer, or both even, will be going towards the "Nick finally gets his a$$ into a Skyline/Stagea after all these years of talking about it" fund!
Any takers? I know there are some DJ's and former-DJ's here on SAU, so surely someone is still out there producing as well?
If someone thinks I'm asking too much, let me know - but please be realistic!!! :)
Nick T
Hey champ.. I am keen on probably both but max i could offer is around 1000 or possibly 1200.. If funds dont permit I may purchase 1 of them.. cheers..
