Hey all,
I have two pieces of music equipment for sale. They would suit a budding producer and both items are in mint condition...
Item 1: Roland MC-505 "GrooveBox" music sequencer
These still sell for over $2,500, and I bought mine about 4 years ago for roughly $2,200. It has ALWAYS been kept under a dust cover, and has probably only received about 80-100 hours use over the whole time I've owned it.
Item 2: Yamaha DJX keyboard
I've had this for about 2 years, and paid about $800 for it. This too has ALWAYS been stored under a dustcover, and again has had hardly any use over the time I've owned it (maybe 50 hours at a guess, if that).
So, how much am I asking for them?
The MC-505 is going for $1,200, and the DJX for $500, and for those who wish to buy both together I'm asking for $1,500 even.
Will try and post pictures/photos tomorrow, please PM for more details.
Nick T.
Phone: 0414-38-55-95
email: [email protected]
Images attached!
The first one is the Roland GrooveBox, and the second one is the Yamaha keyboard (obviously).
Dammit I am really interested, but I was looking at buying something like this later in the year. At the moment its just not feasible until I find another part time job.
If you still have it approaching the end of the year I would be very very very interested,.
Viscount,
it looks like you might be the lucky buyer, the way things are going at the moment... :P
Nick
I am still very interested. I don't have much of a clue about production and have a beast of a computer with software, but no hardware. I'm currently asking some friends in the know about the deal and getting some advice.
I think I would definitely be interested in the keyboard, but I'm not so sure about needing the groove box.
  • 3 weeks later...
C'mon people,
just think - the money you give me in exchange for the keyboard, or sequencer, or both even, will be going towards the "Nick finally gets his a$$ into a Skyline/Stagea after all these years of talking about it" fund!
Any takers? I know there are some DJ's and former-DJ's here on SAU, so surely someone is still out there producing as well?
If someone thinks I'm asking too much, let me know - but please be realistic!!! :)
Nick T
Hey champ.. I am keen on probably both but max i could offer is around 1000 or possibly 1200.. If funds dont permit I may purchase 1 of them.. cheers..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
