Hey all,
I have two pieces of music equipment for sale. They would suit a budding producer and both items are in mint condition...
Item 1: Roland MC-505 "GrooveBox" music sequencer
These still sell for over $2,500, and I bought mine about 4 years ago for roughly $2,200. It has ALWAYS been kept under a dust cover, and has probably only received about 80-100 hours use over the whole time I've owned it.
Item 2: Yamaha DJX keyboard
I've had this for about 2 years, and paid about $800 for it. This too has ALWAYS been stored under a dustcover, and again has had hardly any use over the time I've owned it (maybe 50 hours at a guess, if that).
So, how much am I asking for them?
The MC-505 is going for $1,200, and the DJX for $500, and for those who wish to buy both together I'm asking for $1,500 even.
Will try and post pictures/photos tomorrow, please PM for more details.
Nick T.
Phone: 0414-38-55-95
email: [email protected]
Images attached!
The first one is the Roland GrooveBox, and the second one is the Yamaha keyboard (obviously).
Dammit I am really interested, but I was looking at buying something like this later in the year. At the moment its just not feasible until I find another part time job.
If you still have it approaching the end of the year I would be very very very interested,.
Viscount,
it looks like you might be the lucky buyer, the way things are going at the moment... :P
Nick
I am still very interested. I don't have much of a clue about production and have a beast of a computer with software, but no hardware. I'm currently asking some friends in the know about the deal and getting some advice.
I think I would definitely be interested in the keyboard, but I'm not so sure about needing the groove box.
  • 3 weeks later...
C'mon people,
just think - the money you give me in exchange for the keyboard, or sequencer, or both even, will be going towards the "Nick finally gets his a$$ into a Skyline/Stagea after all these years of talking about it" fund!
Any takers? I know there are some DJ's and former-DJ's here on SAU, so surely someone is still out there producing as well?
If someone thinks I'm asking too much, let me know - but please be realistic!!! :)
Nick T
Hey champ.. I am keen on probably both but max i could offer is around 1000 or possibly 1200.. If funds dont permit I may purchase 1 of them.. cheers..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
