Carbon Fibre Group Buy #3 R32 R33 R34 Etc *** New *** 10/25/2015
Hey guy's ! i am still alive and here i have just returned from my holiday from bangkok been gone for 2 week's+ and attended that thailand connection meet up was crazy ! i think there's 2 guys left over that had delays with there s14 part's i believe they have arrived
  • Like 1
Hey is there an updated list of 32 gtr carbon parts that you can get? or am I better off just finding something I want and asking if you can get it?
R32 stuff
* R32 Dash mount double gauge pod Suit 52/60mm
* R32 GTR radiator cooling panel
* R32 GTS/GTST/GTR wind deflectors
* R32 GTS/GTST/GTR headlight intake
*R32 GTR/GTST mirror cover
*R32 GTST/GTR Top Secret Style diffuser with universal fitting brackets
*R32 GTR OEM front grill
*R32 GTR bonnet lip
*R32 GTR/GTST eye lids
*RB26DETT coilpack cover
*RB25DET S1 & S2 coilpack cover (has screw fittings for ignitor)
R32 Jun Lip $290
R32 AB Flug Lip $320
If there is anything not on the list that you require i can probably still get it i don't have a complete list of newly updated prices but it would be similar to old one
Hey guys... Nothing but great things to say about longz.. Shipped perfect and fitment was good. I ended up doing it myself as well. Here are the results for the r32 ab flug lip bought through longz... Thanks again.
Ps Heard you were asking where I was and when I was gonna pick up the lip from matts lol post-89946-14665941467608_thumb.jpg
Is it like rear pod's for the rear bar ? can get Jun one's , as for spoiler's there's a few different one's to choose from most are in CF though
Nigel : thanks for feedback :) look's awesome and yes i came back 2 weeks later and it was still there lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
