Hi all, I have recently started planning out my mod list for my 33, (as soon as I can find a nice one), and I could use some opinions on what colour Grid's people think would look best. We're talking a white R33 series 2. I was thinking going with white, but something slightly different and a bit whacky could be a possibility. What do YOU think?
Available colours: http://www.rotawheels.com.au/wheels/rota-grid-r
Cheers :yes:
https://www.sau.com.au/forums/topic/460630-rota-grid-colour-choice-help/
Any of the neutral colors like Greys and Blacks will work and be a safe bet.
White on white ill bet the white wont match exactly or any other bright strong color wont work unless you want to scream look at me im a drifter.....
Id be going Blacks or Greys.
