Looking for new wheels for my R33 GTR. i'd like to fit 18x11s. 295/30
Offsets between +15- +18. I do not want to roll my fenders, But i dont mind a little rub on full lock. anyone have experience?
Car is lowered on JRZ suspension, but not tucking tire
No much info out there on 18x11, +18 seems to be "GTR size" but no details on rubbing or rolling fenders
All i've found:
18x11 +16
Here is 18x11 +20
thanks!
Edited by sixmassive
https://www.sau.com.au/forums/topic/461116-18x11-on-r33/
Found something, still no info on fender rolling.
posts 2593, 2596, 2597
"R33 GT-R with 18x11's +18 all the way around and 285/30's. . .lowered but not tucking. . .slight rub at full lock when hitting a bump, not cambered to hell either. . .runs like a dream
http://www.sau.com.au/forums/topic/84208-wheel-sizes-offsets-for-skylines/page-130#entry6951583
RS05RRs are +16
ZE40s are +15
https://www.sau.com.au/forums/topic/461116-18x11-on-r33/#findComment-7639862
You are going to have to roll guards with those spec wheels. Seeing as how I said 10.5 is the perfect fit. A 11 +15 is another 1/4inch outward and will most definitely be poking unless you camber it in.
Why on earth do you require a 11" wide wheel?
10.5" is already dick load enough
https://www.sau.com.au/forums/topic/461116-18x11-on-r33/#findComment-7640416
Ah ok, I'm picking up what you're putting down
Need; not really, wouldn't mind it tho. but if i have to roll them, 10.5s will be it.
I'm on 18x9 +20s w/ 255/35 right now. it grips, but at the track, I can feel it sliding around. I'm also a little tired of my g-games.
https://www.sau.com.au/forums/topic/461116-18x11-on-r33/#findComment-7640460
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
