A daily or toy?
I've been contemplating moving mine on. It's not really suitable for a daily unless you're a sadist. It is, however, the perfect base for a weekender. It does have a few issues, however. It had a tree fall on it so some dings on the roof, bonnet and front left guard. It also needs new bearings somewhere (not sure if alternator, PS pump or something else) and a couple of other little bits and pieces. Otherwise it's very solid and quite stout with 235rwkw (I have removed the front prop shaft) now and capacity in turbo, injectors etc for 300+. All it needs is a new FMIC.
I would want the upper end of your budget, however. I've pumped nearly $10k into recently (turbo, injectors, clutch, fuel pump, coilpacks, big brakes, wheels and tyres) so would want to recover this.
Sound like something you might be interested in?
Oh, it's yellow, too.
I'm not set on selling it, but it is something I'm considering. I have no need to sell, but my want for another Datto 1600 is extreme and I don't think I can convince the missus to let me own three cars and two motorbikes. Something has to go first.
I have been thinking of selling mine but am located in Sydney. Auto s2 c34 with dayz options. Going cheap, the only thing it needs is rust in doors fixed going for $7k
Recently spent over 6k on it, replaced all four rotors and pads, front drive shafts, rebuilt auto trans, split fire coils packs, coil over suspension all round, new alpine head unit, 3 inch exhaust from turbo back and has been serviced every 5,000 km.
Edited by stock stagea
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
