Hi all,
I have for sale the following used items from my R33 GTR:
Kakimoto.R Stainless Cat-back Exhaust System with Metal Cat $450
Apexi GT Spec Front Pipe $250
Apexi Power Intake Kit $200
OEM Sway Bars $100
Cat, front pipe and pod filters were on the car for less than 8000 km.
All items in good condition.
Local buyers only please. I am located in Madeley WA. Mobile: 0439657815
Hey mate, are you able to have a look in the mid muffler and tell me how restrictive it looks?
Also if it tapers down to smaller than 80mm in any places like the flanges?
Same with the front pipe, is it 70-80 at the inlets and outlets?
Hi mate,
Took the below measurements.
Main muffler portion inlet: at least 85mm
Mid muffler portion inlet: have not measured as cat still attached
Mid muffler portion outlet: at least 85mm
Front pipe inlets: at least 70mm
Front pipe outlets: at least 75mm
Diameters may actually be larger depending from were you measure from, but I measured purely the open area so might be a bit conservative. Hope that helps.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
