have to sell my r34 skyline due to starting apprentice work soon and need a more convinient car to get around in,very sad to see it go must be done and soon! its a head turner and very clean car not many arount like this,..
5SPD manual
106,200kms
New alarm system
New splitfire coilpacks
5puk hd clutch
Blitz Nur spec exhuast
Custom air intake
Wheel alignment n tires done not to long ago
The car has rego till 30/3/2016
rwc can be included for the right price, i got the rwc as the car is now so wont be any different if u do it urself! No clean r34 like this for sale at the moment and especially pplate legal manaul coupe
$13,500
CALL me on 0434640257post-140846-0-32570700-1448864876_thumb.jpgpost-140846-0-22734000-1448864834_thumb.jpgpost-140846-0-66905200-1448864843_thumb.jpgpost-140846-0-10666100-1448864850_thumb.jpg
https://www.sau.com.au/forums/topic/461372-manual-r34-25gt-p-plate-legal-vic/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
