Up for sale is a few things of my 33 gtst!
R33 airbox with snorkel $120
Engine brackets $30
green label afm $40
Rb25det turbo with dump and a couple of lines $200
Stock oem rb25det series 1 coilpacks $80
Radiator $70
Located Melbourne north!l will post at buyers expense
https://www.sau.com.au/forums/topic/461384-r33-gtst-parts-wrecking/
  • 5 weeks later...
  • 3 weeks later...
