Wth is a crabs fest or crabs?
Hahahahah there's a crab Festival this weekend in Mandurah , and its the same date that we have for the JDM meet and greet so... Cut it short we're cruising down to mandurah for crab fest instead the JDM meet due to the bad weather [emoji23][emoji23][emoji23][emoji23]
And ah I see. Had no idea crab fest was thing [emoji23]
Hahahahahaha yea it was and its big thing! well it's more like fun festival if you love seafoods and foods :) I don't cook , I hate cooking, don't want to cook and won't cook but I love foods & seafoods Hahahah does it make sense ?
Think the meet and greet is still
On unless if they announce cancellations by tomorrow , so far 5.30 meet up is still on ? City West opposite Harvey Norman and cruise all
Together to Cockburn ?
hi good peoples ,, my story is similar to bg11,s .. Ive been a member for a few years but, just been busy working or .,, yep, Just busy working when ever some thing has been happening ,, .ill drag the Dato out of the shed and ill join you guys if that alright with you .. ill take the redbacks who live under the car for a cut ,, i mean drive ,, ( the ol Fart will tag along behind, lol ) ..
:thanks:
  • Like 1
Does anyone know the map? I ask cause it starts at 4 I think im sure if we rock up at 6 or so they will have moved on? Im happy if you guys want to meet up earlier and then let ne know where you are around 5 or so then no one misses out?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
