Hey guys
Have abit of an issue here, I'll run through quick details so can have an idea where I'm at.
Have just done a reco on an standard rb20det, had a hone, rings and bearings.
Had the head checked and recondition, had a few leaky valves, so spent abit having it all sorted out.
Had the lifters out while
Sent it away, soaked and pumped most of the old oil out of them cleaned them abit. then soaked then in new oil and pumped them in container of new oil
Prior to install.
Engine is in, and have the covers off trying to get the top end pressurised and pumped with oil.
Appear to have pressure, oil Pump is working fine. Have even pulled the sensor out on the block, and pressurised it from there with oil few times while cranking it over by hand.
Not really seeing the oil or much oil making it to the head or through the lifters yet.
I'm constantly checking by pushing down on the top of the buckets to see if they are still soft, and most/almost all still press down easy enough unfortuntely.
What are your thoughts on the situation, will I need to Pull the front off and cams back out to try bleed the lifters up and re-install?
Thanks for your input
Edited by 20SIX
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
