Looking For: Someone To Help Source Rb30 Short Blocks To Export To Canada
Hi guys,
I've been trying to source some help in exporting a few RB30 short blocks here to Canada. I'm hoping to get 2-3 of them together so my friend And I can build some RB26/30's for our race cars.
Im hoping I can find a kind Austrailian in a sea port area like Brisbane who can source the blocks and strap them to a pallet so I can have the freight company pick them up and send them on their way.
I was in contact with an engine importer but j guess they lost interest when I didn't want long blocks to save space to ship a third block (just as a spare incase on of the other ends up unusable)
If anyone can help me out that would be amazing
Thanks!!
Rob
Have you tried looking on gumtree?
I have been looking on Gumtree and even posted an add there. However my ad keeps being taken down and finding someome on gumtree who has 2-3 short blocks to ship.
I wanted to try SAU to see if a member wanted to make alittle cash for car parts off some old RB30's they have kicking around
No worries mate if i see or hear ill let you know
Thank you so very much.
I should add, Im not necessarily looking for someone who has 2-3 short blocks but maybe someone who has one or knows of someone with one and would collect up a couple more off Gumtree or other classifieds so they can make some money.
I had an Engine company that normally deals in Jap import engines willing to help but they wanted me to buy whole drive lines (engine and trans) at over $1000 each. I see engines on Gumtree for less then $300 and I dont need the trans or even the top of the engines so shipping the whole drive trains was going to very very expensive and totally unnecessary.
I am trying to avoid hopping on a plane, renting a Ute and driving around pulling them out from under peoples decks and junk yards haha.
Edited by Deejaytexhfx
Yeah stuff that mate when i get some free time ill have a hunt around for you. Are you after a8 block or just any rb30det block
I believe I am after A6 Short blocks aka the RB30E. I know for my own build ill be installing new Piston and Rods along with all bearings ect and Im pretty sure my friend will end up doing the same so buying the rarer A8 or RB30ET blocks would just be a waste.
Will look around for you if a sydney port will suit
Thanks brother that would be greatl! The shipping company has offices in all the ports, I just got a quote from Brisbane because that where this shop was that said they could help us out. I cant imagine it being too much more so long as im shipping from the same side of the country haha.
You all have been a great help i really appreciate it
Sent you a pm mate
Thanks Mate, Sent you a reply.
If anyone comes across anything, that would be stellar!
You guys are all awesome
Rob
Still searching...
Sadly shipping from Australia to Canada is half the price of shipping from the US to Canada... Plus the AUS and Canadian dollar are much closer then the CAN to US Dollar is
Ok so found a few blocks around, theres definitely no shortage here in aus. Whats your budget on just blocks alone without freight costs? What im thinking is i may be able to go round with a trailer or delivered to me depending on where they are sourced (wreckers would deliver ) put them all on a pallet and get them picked up from me using courier and deliverd to melbourne port, then from Melbourne to you. Depending on how much work i do & cost of engines obviously i will work out what its worth. Its even easier if i have a few weeks to hunt down some bargains, buy and store them till i have everything you need.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
