Hey guys,
Selling these extra parts I don't need as I have an ECU with map sensor and I'm going to go with an E85 walbro suitable pump.
- The 040 has never been used as you can see from the strainer. I bought it from JustJap about a year ago for $210 if I recall. It's currently wired into my HR31 cradle but has never been in the tank as my car isn't finished yet and I want more power than this will flow. Would make a great upgrade for a mildly modded skyline.
$150
- Z32 AFM + Plug - I bought this off of a forum member, I was going to go with Nistune or PowerFC but I have bought an Adaptronic unit through Stao. So I no longer need this. Would suit someone with a Nistune/PowerFC. Rear mesh has slightly detached itself but can be removed, doesn't effect the function of it at all.
$150
I'm located in Western Syd. Happy to post to other states.
Edited by JezR31
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
