1999 model championship white Integra Type R, build date october 1999.
Vin number identifies it as 2000 model at honda.
excellent condition, 57,XXX original kms, oil changes every 5000kms, only ever used redline 10w 30 motor oil or motul chronosport 10w 30.
Modifications.
Engine:
K&N pod filter in stock air box
Ngk spark plug leads
Ngk spark plugs
JDM 4-1 extractors
custom 2.5" stainless steel mandrel bend b pipe
carsound 2.5" hi flo cat
5 zigen fireball muffler 2.5"
Exedy heavy duty clutch put in 5000 kms ago
jun 4.1kg lightened flywheel.
Spoon reservoir covers
Other:
Bilstein height adjustable racing spec coilovers(very stiff!!)
16" JDM light weight wheels with bridgestone potenza re711 rubber.
Genuine honda type r mats
Factory optional bodykit,side skirts and rear skirts.
Comes with factory optional rear strut bar
Clear indicators
I have all original parts (except for the wheels) ,if u are serious i can arrange for the car to be put back to stock .
This car has been looked after very well, it has only been driven on the weekends, has never seen a single track day .
$27,500 ono with all modifications.
Located in Melbourne
Contact <removed> if interested
looking for quick sale, no time wasters please.
Thanks
Tian
https://www.sau.com.au/forums/topic/46299-fsintegra-type-r/
hey guys, this has to the cleanest and most looked after type-r in melbourne. i personally know the owner and takes great care of the car. the car is extremely quick, looks amazing and sounds sweeeeeettttttt...
tian mate, heres a few more pics for ya.
cheers.
https://www.sau.com.au/forums/topic/46299-fsintegra-type-r/#findComment-947271
    • To be determined, Luke, to be determined. 😁 Definitely the car
    • It might be worth having a good look at the chassis behind the bumper then; most people prefer the series 2 look so it might have been changed to cheaper parts as part of an earlier repair
    • The car itself a series 2. I was just curious about the headlights and just wanted to confirm that they were series 1. Good to know the rest of the front end is series 1. It’ll be easier for me to find parts on the aftermarket side of things lol
    • If you've wired up the coils & injectors properly, & have the neo CAS loom for the trigger, it should all work. The VCT works the same way so just different plugs between s1 & neo. Assuming DBW if no IAC. Don't bother with the stock boost solenoid with g4x.
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
